Cert Help | on ElectriciansForums
Discuss Cert Help in the UK Electrical Forum area at ElectriciansForums.net
SKY
currently filling out a EIC for a CU change, on the schedule of inspection.
One of the boxes asks about routing of cables in the correct zones.
As its a only a CU change I would have no idea.
Do I put this as LIM?
LIM is for use on EICRs only.
You only need to inspect and test the work covered by the EIC.
Any tick boxes on the schedule of inspections which don't apply to the work covered by the EIC are N/A.
Reply to Cert Help in the UK Electrical Forum area at ElectriciansForums.net
Yes I think back in the dark old days they were called deeds but are now called contracts and some still refer to it as deeds like I did! Sounds...
They are excellent, I have used them a few times for consumer unit relocations! They can get a bit tight with cables if you're using all the...
