Certificate for building control!! | on ElectriciansForums
Discuss Certificate for building control!! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
E
eck
Hi folks no doubt this has been asked a few times,,
Im doing a homer and running a new lighting and ring main circuit (house extension) and when it comes to the test sheet and certs can i download one of the net and give to building control along with a copy of my grading card and a copy of the calibration cert for the tester used??? or does it need to be a SELECT or similar certificate...
All help and info would be great....
Reply to Certificate for building control!! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
"So the question is to register with NICEIC/NAPIT for part P regs will they require other proof of qualification?" Why not contact them and ask...
