B
BlueToBits
I thought it was about time I dragged myself kicking and screaming into the 21st Century so I've been looking at Certificate form filling software.
Castline are doing an entry level domestic installer version as a bait to get you hooked, but it's not really enough without committing to another £300 for a usable version. Being a stingy *******, I don't want to pay the earth for something that I will have to replace when the 17th ammendment comes into force later this year. Amtech also want £300 + £320 for the update and the £255 NICEIC offering (without the certificate numbers) includes 12 months of updates but it has no smartphone support.
Would anyone who uses form fill software like to share their experiences?
i use similar. bought off ebay, mine need open office to run, but that's free and filling in is easy peasy
Elecsa have just joined with a company, I think it's called pirform and it's £80 trial seemed good I think I will buy when I can
them EBAY certs are flaming rubbish!! i left some nice feedback for the seller!! hahahaha!
use Easy Cert as simple and clean!
you must have got the wrong ones. i've no probs with mine. everything needed is on them. what was wrong with the ones you got?
cheap and nasty!!! left the same seller as in link bad feedback!! just click him to see!!
We use Castline Formfill 9, the full version-after about 50 updates, it's pretty near perfect!
You get what you pay for with software, 70% of our business is PIR's and they have to look the business and have the features that save you hours on large reports-DB schedules at the press of a button, watermarks for draft/original/copy, .PDF production etc.
I recently bought the NIC software for use for domestic installations. It seems to work generally, however if you find the plain paper use attractive, you will need to find buying printer cartridges fun also. Don't expect to much of the verification of test results, it's buggy, although we shouldn't be depending on that anyway, before I get reminded of that........Phone support works well and will confirm bugs as you find them. That said, some sort of software does produce better certs and save time, although you might find yourself wanting to take a laptop and printer to work and maybe an inverter etc etc. There's a £10 min order charge on the cert no's too, so if you only want one batch it's dearer than you think.
Hope this helps, but bear in mind I've only been using it for a couple of weeks.
I used to use the rubbish ebay ones too, which almost drove me bonkers. Love the tysoft eastcert product. Bit pricey, but fair enough, it is specialised software, and the guy who is developing it has to make a living too. It runs perfectly and does exactly what I want it to, and excellent support aswell. Once you've gotten over the original license fee, the £60 a year maintenance ain't too bad..
I have used Amtech when working as a QS. Good software but pricey. They were slow to update their Emergency lighting certs when it changed to 17th Edition and I got a bo***cking from NIC.
When I started up on my own did not want to go back to paper certs so bought some ebay ones, the layout was poor and some did not even conform to the 17th Edition. So ended up making my own using NIC certs as a guide. On my assesment the NIC inspector was happy with them and remarked how much they looked like NIC certs.
Im selling them on Ebay now, not saying there as professional as Amtech or Easy cert but for £5.99 I think their a good alternative for those on a low budget. If any one does find a mistake with them Ill correct it and replace for free.
17th Edition Electrical Certificate Software on eBay (end time 09-Feb-11 20:56:24 GMT)
Pride, your listing says they are complient. That should be compliant, mate. I spotted those the other day, but have been wary of certs on ebay since buying the NationalCerts ones a while back. They had several errors - I spent time telling them about it, had to get others real quick for a job I had, and they promised to update them but i never got the updates. Their EL certs were not to current BS5266 and they had their company name still listed on some of the certs. They were not a bad effort (apart from the out of date ones), just did not have the attention to detail I am used to applying in my work.
I read your comments, Steve. I actually gave them positive feedback, but this was before I clocked some certs were out of date, and they had their own company name still embedded in others. Tried giving them feedback about what was wrong, but never got the promised updates. Wasted my money (and time) in the end.
By the way, what's the three-hole balaclava for? Planning a bank job?
Can someone explain how you go about using this software please.I'm guessing you take a laptop or somekind of hand held device to the job,use this to enter your test results and then print off cert and give to customer? Is this the case because it sounds a bit much to me. thanks
With the Easycert software I usually start by printing out a blank form (called a site survey form), or with some of the information already added into a new cert, such as client details etc, then take that onsite and fill in the blanks as I go. Then back home enter the remaining details into the form and print it out. The software checks I haven't missed anything, and does some checking of the values entered. It also keeps track of all my certs, and includes an online backup facility so all those I've issued are safe even if I lose my laptop. There is a PDA option if you want to enter the info onsite with one of these devices but I don't use that as I find a pencil much easier to carry around!
I bought some of ebay for £7.99, not quite as easy to use as the above but they are fully editable so you can update them your self when you want and save & add images if required.
ELECTRICAL TEST CERTIFICATES 17th EDITION SOFTWARE DISC on eBay (end time 06-Feb-11 13:46:02 GMT)
i use the same sort of software, pretty decent been using it 3 years now. had to edit columns on test result page quite alot though to fit in numbers better.
i would like to use tysoft easy cert but its a bit pricey for me at the moment. (tried the trial and it looks really good)
I use Hollycroft software. I think it was £295 for the full package and i'm sure they do a simpler package for £195 ish. More than just cert's tho it has office, admin, estimating(lame) and lots of other handy stuff i dont use..yet. I'm pleased but have never used anything else
I use a mixture of programs for different things have castline formfill level 2 full version and cable calc use these for niceic overprint certs then use hollycroft contractor pack for certs like fire alarms and em lighting both of these cost in round 95 + vat but that is for updates and support as cant remember initial outlay for the programs
Out of interest, why don't you use Formfill for fire and emergency lighting certification?
Only reason is force of habit lol always have etc and the way i sort of keep programs are niceic certs printed on castline and eveything else on hollycroft but in theory the both programs are the same hollycroft has slightly more features but castline to me is a quicker program and for example filling in periodic reports castline provide a drop down list and you just select a fault if it matchs ones on list click the button and its all on cert complete with coding which is handy
We moved from Amtech to Castline Formfill for all certification and I must say, after many updates, that package is now excellent and very good value!
just bought the elecsa version of pir form for £75.
Is the dogs too!
has inteligent software which automatically quotes specific regs to probs picked up on PIR's etc.
check out their demo on web!
Home - PIRform
Anyone that buys Hollycroft software is paying well over the odds.
It amazes me that they call it software, because it isn't stand alone, if you don't have word and excel, you're pretty much stuffed. For the money they ask I'd expect stand alone software. All it is is a collection of templates some of which are pretty lame, especially as has already been pointed out the estimating section.
Maybe a daft question but these prices for software are "One off prices" right?
Theres no annual subscription or any other fee's?
anyone help me out on which software to go for for all emergency lights and fire alarm certs aswell as BS7671 certs?
ebay. all certs on a cdrom for a few quid, inc. fire and em lighting. some, though require open office to run, but that's free anyway. the one's i use are called national certs.
got to be worth it at that price, even if find out its no good...
I can see it doing the job though.. Seems very much the same as hollycroft software..
I really like the look of Home - PIRform for elecsa certs... But £75 every year for basic version...??
are all the rest yearly subscriptions.. (excluding ebay certs)
This all depends on what your requirements are, if you do many PIR's, EIC's a week then a good software package is far more professional and can save you and your chaps many hours with multi users and master databases etc.
If on the other hand, you knock out a handful a month then it would be pointless.
the link i've posted is the ones i use. you can't run from the disc, you have to download into your pc. runs with open office. takes a bit of playing with to get used to it, but i find it excellent. does different clours for nic, napit, elecsa as well.
So if you run a buisness with a handfull of blokes working for you you would recommend buying a decent software package? amtech.. easycert etc...
and if your a one man band then the ebay certs are a good choice?
I dont mind paying a one off fee for the software and an unlimted licence key that never expires.... but im not prepared to pay £££ subscription fee's
Certificate Software. What do you use?
Business Related
BlueToBits,
Voltimax,
