Certification :: How do you ID a cut out fuse if you can't see the label? | on ElectriciansForums
Discuss Certification :: How do you ID a cut out fuse if you can't see the label? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
DaveyD
Warminster
Hi Everyone
On occasion when the cut out fuse sticker has fallen off or is unreadable what do you do?
Also, have you always trusted the sticket on the case? For example, I've just seen a TT system with a sticker saying 100a.
Thanks in advance.
David
Reply to Certification :: How do you ID a cut out fuse if you can't see the label? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
