certification | on ElectriciansForums
Discuss certification in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
L
leekemp85
Is there a web site that I can download a electrical certificate to show the labc.
many thanks.
The Institution of Engineering and Technology - The IET that will get you to the home page, why do the labc want one have they never seen one before and if the answer is yes why does that not suprise me:)
Chris
Dont worry about that as the IET writes the regs nobody will argue witht the Cert. The NIC ones are more indepth but the main info you have to fill out is the same.
Hopefully thats good, just rewired my sisters kitchen as a faver and building control wants a cert. Boss would not see the funny side of borrowing a NIC cert. I do think ÂŁ175.00 ish is a bit much to comply with part P
Reply to certification in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Persons who are not registered with a self-certification scheme - including DIYers - will need to notify or submit plans to a Building Control...
It’s sad that you had to say no more money to them for them to pull their fingers out.
