certs 2391 | on ElectriciansForums
Guest viewing is limited
Discuss certs 2391 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
E
eganelectrical
Ok, if I have the 2391 do I have to join a body (NIC, ECA) to supply a certificate to domestic owner after I carry out works? Or can I fill in certificates from the regs and just hand them over? Do building control have to be notified by law??
1. No
2. Yes
3. Yes if the work is done in a special location, or if the work is complex i.e Consumer Unit replacement.
But take the advice given earlier and look at approved document P, free download.
Cheers............Howard
Reply to certs 2391 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
OLEV is now OZEV, in case you weren't aware. Installing EV equipment is not as straightforward as many might think. There is a Code of Practice...
loz2754
L
It’s sad that you had to say no more money to them for them to pull their fingers out.
Recommended Sponsor News
Hi everyone,
