Certs | on ElectriciansForums
Discuss Certs in the Talk Electrician area at ElectriciansForums.net
R
rapier
HI
My boss as recently finished 2nd fixing a property and he has put a 17th edition 7x7 board on.
Hes also put a 2.5mm swa into the garage under the ground in a soil pipe. He left the swa in the house my the cut out.
So he had his 25mm tails in the isolator and he took 2 10mm tails out with it into a 2 way ccu with rcd.
So he told me to go and test the whole installation as he doesnt do much testing
I have tested all the house today on the 7x7.
I am wondering where i put my results for the garage fuse board does this mean a new set of certs for this.
Hope i make sense.
I would be putting it on a seperate cert as it isnt fed from the main board. If you took the supply off an mcb in the 7x7 board, this would b classed as a dis-circuit. Hope this helps
The installation although having 2 dist boards both come from the same origin of the supply therefore are considered as one installation
The EIC should contain 2 sets of test resuts for each dist board contained in one EIC
Reply to Certs in the Talk Electrician area at ElectriciansForums.net
Went into an MCCB, terminated very nicely thank you very much, however it was just me doing some training with crimping. 'introducing extra point...
Sounds more positive.
