screech
Hey guys.
Got a customer with a problem and looks like it's on the cesspit circuit.
The cu has an rcd main switch which is apparently tripping, mcb for the cesspit goes straight into a DP switch, then off in swa...
I got them to turn the mcb and it's DP switch off, and they say it's come back on.
What I don't know is, what exactly is a supply to a cesspit for?? Never come across one before.
Cheers
they give a bit of rcd trouble alright
basic unit is prob as well off sharing an rcd-give you some fault indication
some have an alarm pair and use 2 rcbo's-1 for pumps and 1 for alarm pair/float switch
Cess pit circuit...
Australia
screech,
davelerave,
