Hope I've got this right if not im sure i'll here about it this is something we give out to landlords that own properties here in Spain using quotes from UK law to help in the understanding.
If you are in any doubt about the wiring or the safety of any appliances
consult a qualified electrician.
Regulations
There is no statutory obligation on landlords or agents to have professional checks carried out on the electrical system or appliances. However, under Common Law and various statutory regulations: The Landlord and Tenant Act 1985, The Housing Act 2004, The Electrical Equipment (Safety) Regulations 1994, and the Plugs and Sockets etc. (Safety) Regulations 1994, both of which come under the Consumer Protection Act 1987, there is an obligation to ensure that all electrical equipment is safe.
In January 2005 new legislation under Part P of the Building Regulations make it a requirement that for certain types of electrical work in dwellings, plus garages, sheds, greenhouses and outbuilding comply with the standards. This means a competent electrician must carry out the work. For DIY electrical work you must belong to one of the Government's approved Competent Person Self-Certification schemes or submit a building notice to the local authority before doing the work.
Compliance
We strongly recommend that any Landlord, regardless of whether they see themselves as running a business or not, should make absolutely sure they are complying with these regulations to ensure that all electrical equipment supplied is safe.
In order to do this we recommend
- Annual visual inspections by the landlord or agent (Long lets only) - recording this on a safety checklist. On holiday lets we recomend checks between summer/winter season.
- Inspections on tenant change-overs, recording electrical equipment, its condition and fuses fitted - see PAT Testing.
- Periodic inspections of electrical equipment by a qualified electrician.
- 5 yearly inspections by a qualified electrician to ensure safety and that the electrical system complies with current electrical regulations.
- Keep all records of these inspections.
