Rookie978
Hello,
I was giving project to replace our old temperature heat chamber/oven with newer one. It required for me to use the same timer from the old oven to use for the newer oven. (timer and oven have the same spec 208V/20A with L6-20). I worked with electrical, but not often and still learning as I'm going. So with that being said, of course the newer oven electrical would be completely different wiring. As of now I have both oven and timer on and up running. However, I can not manually shut off the timer and I also cant shut off the timer with programmed to the set time. I believed i need to broken the leg in order to shut off the oven, but im not sure which wire should i connect too?
The timer have 3 line
1. is going to Neutral
2. is going to HOT
3. is the Load.
Please help me, I know i am close just not sure which wire to close the leg. If you guys need diagram of the oven I can provide.
thanks in advance.
2. is going to HOT
3. is the Load.
thanks in advance.
