Change 7 day controller to a 5+2 day controller | on ElectriciansForums
Discuss Change 7 day controller to a 5+2 day controller in the Central Heating Systems area at ElectriciansForums.net
O
Octopus
OK, I've done my fair share of running cables and doing some connections for heating systems but don't know the controller market very well.
A regular customer of mine has a BG UP2 (picky below)
[ElectriciansForums.net] Change 7 day controller to a 5+2 day controller
Is it possible to get a controller that would directly replace this unit to give the 5 + 2 day control.
On the back of a bg up2 is some little pegs u can change, one end does 24hrs the other end does 7 day and if u remove said peg it turns it in to a 5&2 prog from memory. If u still want to change it danfoss one should fit think Honeywell won't.
Hope this helps
Reply to Change 7 day controller to a 5+2 day controller in the Central Heating Systems area at ElectriciansForums.net
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
