Change to 3 way lighting. | on ElectriciansForums
Discuss Change to 3 way lighting. in the DIY Electrical Advice area at ElectriciansForums.net
Deleted member 105832
Hi,
Our kitchen has 6 ceiling lights all controlled by any of three switches.
One of the lights is above our breakfast bar and I want to change a nearby switch to control just that light only while leaving the other two switches still switching all six lights.
Is this a simple re-wiring job?
Thanks.
Hi,
Thanks.
No not a simple job, maybe for an Electrician, but a DIYer a nightmare would ensue.
Lots of building fabric would be damaged walls, bedroom floors and ceiling maybe, depending on how it was / is wired.
one of the staff members that live near you could pm him.
you could ask him for advise .
If you Know what you are doing its quite straightforward and could involve a bit of mess depending on what your walls are made of. The fact you ask suggests you'd be better off from a safety perspective and time one of getting a local electrician in to do it.
Thanks for the replies, I'll either leave it or speak to my local electrician.
Thanks again.
Reply to Change to 3 way lighting. in the DIY Electrical Advice area at ElectriciansForums.net
Thanks for the replies everyone, much appreciated. I've been in touch with our electrician as we're going to have him swap out some sockets from...
It does seem to me that there's a capacitively coupled voltage to each set of downlights (on the light side of the switch), and when you put the...
