SirKit Breaker
I have got the qualification handbook from C&G for the new courses to replace the 2391.
Level 3 Award in the Initial Verification of Electrical Installations. C&G 2394-01
This is made up of the following,
Level 3 award In the Periodic Inspection, testing and certification of Electrical Installations. C&G 2395-01
Reading into things, it looks like they have split the 2391 in half, and made it twice as long which should make it a bit easier. BS7671:2008 (2011), and the existing GN3 are still the bibles for both courses.
They have also introduced an new one.
Level 4 Award in the design and verification of electrical installations, C&G 2396-01, but this up a level, so i wont go there for now.
Cheers..........Howard
- Unit 301, Principles, practices and legislation for the initial verification of electrical installations. Assessment method, online multiple choice test. 40 questions, 1 hour duration.
- Unit 302, as above, but assessment method is Written test 3 hour duration, set and marked by City and Guilds.
- Unit 303, as above, but assessment method is Practical, and is set by C&G, delivered and marked by the assessor/tutor, and will be externally verified by C&G to make sure it is carried out properly.
- Unit 301, principles, practices, and legislation for the periodic inspection, testing and condition reporting of electrical installations. assessment method, online multiple choice test, 40 questions 1 hour duration. (this is the same test as for the 2349-01)
- Unit 302, as above, but assessment method is written test 3 hour duration, set and marked by C&G.
- Unit 303, as above, but assessment method, practical set by C&G delivered and marked by assessor/tutor and will be externally verified by C&G to make sure it is carried out properly.
