Hi Guys,
I'm doing some work for a friend who needs me to test his house so he has a valid test cert as he is going to be renting it out. He has an 8 way hager board with no rcd protection. There is no earth down to the light switches on the installation. I've been tod I can put a split load board in (not enough space) or replace the MCB's with RCBO's. Could I fit an 8 way DB with an RCD.
Cheers.
Cheers.
