Changing downlight bulb | on ElectriciansForums
Discuss Changing downlight bulb in the UK Electrical Forum area at ElectriciansForums.net
himlas
New York
Hi,
One of the downlights in my bathroom started to flicker and I tried to turn it around.
Is this possible to change? How?
[ElectriciansForums.net] Changing downlight bulb
Hi,
Hi and welcome to the forum.
It may have a spring clip on it. Can you get to the other side of the light, where the wires go?
Something like this, maybe.
those are horrible to get out. usually fitted in with a rubber sucker. with the circuit isolated, get a couple of slotted end screwdrivers and prise the fitting out.( watch your fingers, the springs are a mousetrap) then you can get a grip on it .
Reply to Changing downlight bulb in the UK Electrical Forum area at ElectriciansForums.net
Neutral and live
clearly a wiring or connection issue, lets see a picture of your connections
