people do you all believe it is ok when changing light fittings, to use connector block and push into ceiling.... would you tape connector block up..??? cheers for your views
Discuss changing light fixtures in the Talk Electrician area at ElectriciansForums.net
so do i, but should they not be in an enclosure to reinstate double insulation.I use Helacons
I think i've missed the boat on all this wago block lark? what can a wago block do that a conector block cant? plus im not limited to how many cales go into a conector block. please fill me in!
ta, Jason
wagos or hellacon connectors. push in maintenance free, up to 8 ends ( 1.0mm - 2.5mm ) in one block. google "wago" or " helacon". but don't make the mistake some of us have done by putting a L and a N in ther same block!! nice bang!I think i've missed the boat on all this wago block lark? what can a wago block do that a conector block cant? plus im not limited to how many cales go into a conector block. please fill me in!
ta, Jason
Like other posters, I wouldn't do it at all. Wagos all the way, and in the case of lighting, in a maintenance free JB.
Reply to changing light fixtures in the Talk Electrician area at ElectriciansForums.net
