O
One_of_them
guys,
cables coming through tiny hole in ceiling into pendant. Replacing for fancy fitting with terminal block that wont accept anything. I still cant quite understand how to get a choc box into the ceiling void without creating a hole bigger than the fitting as it's base is no bigger than a pendant base. While also been able to get a fix for the bracket???
can I use wagos and have them between the fitting base and ceiling without been in a box?
shout if this dont make sense :sad3:
