Discuss Changing, single to double switch and adding a new light in the DIY Electrical Advice area at ElectriciansForums.net
Difficult to actually understand what you are trying to do, from what I can see I have to be boring and suggest you get an electrician in, you have no neutral and certainly cannot connect one even if you found one through the switch , the whole thing looks messy and not really in this case a DIY jobHi,
I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to the light. (earth is in choc block at switch and light fixture)
I want to add a second switch like this
Does this look ok?
Thanks,
Derek.
Well spotted!looking at the initial photograph on the OP...... did someone actually earth the plastic pattress box?
Reply to Changing, single to double switch and adding a new light in the DIY Electrical Advice area at ElectriciansForums.net
