I've been asked to remove two storage heater and replace them for electric radiators. The storage heaters are on their own dedicated circuits protected by 16A mcb. There is no RCD protection. It is currently on E7 but the customer is planning to move to a single tariff.
I will change the storage heater socket to a fused spur socket but would I also need to change the mcb to an rcbo?
It cannot be used as a plug socket so I can't see that it would need to be protected by an rcd other than the fact that I cannot determine whether the cables are buried at a depth of more than 50mm.
Apologies if it seems like an obvious question but I am newly qualified and want to know I've got it right.
For a storage heater to contain asbestos it would have to be over 40 years old as manufacturing removed use of asbestos containing materials in 1973/4.
That's weird, any idea as to why they stopped in 1974?
Legal bans on various forms of asbestos didn't start until the 80's and the final total ban didn't happen until 1999, so i assume there was another reason to stop using it in storage heater bricks?
No idea I know various restrictions have been imposed over the years and as you say a total ban didn't happen until 1999/2000 and that probably will surprise many people.
Apparently as early as the 1970s Dimplex realised that by removing the asbestos the 'heaters' could perform even worse; so they did it!
Warminster
Changing storage heaters to electric radiators
Calscot,
richy3333,
