P
Phil
take a look at this the software is fantastic and has been kindly donated by solutions electrical. here. Ray Thompson has been kind enough to donate this to us. this retails at 749+ vat. it might be worth while you telling the boss at work about this if you are working for a company as this is top software have a look through what it does.
auction will run until friday the 10th of september at 10 pm
Cable Calculations:
Find all your:
Cable sizes and capacity.
Voltage drops
Conduit sizes
Fault Levels
Fuse/CB sizes
Working Temperatures.
Touch Potentials.
Input Your own Cable size!
More Info
Earth Loop Impedance Testing:
Minimum Trip current needed to comply with:
Earth Loop Impedance test
Actual let through current
Maximum impedance values (Ze)
and the actual impedance values (in ohms)
Total impedance values(Zs) for the complete installation (in ohms)
Touch Potentials.
More Info
Maximum Demand:
Perform a maximum demand in just minutes for:
Domestic
Commercial
Industrial Installations
More Info
Test, Reporting & Inspection forms:
Complete all test, reporting and inspection forms for all installations,
Keeping and maintaining detailed records of your work
Electrical Test Reporting
Electrical Installation Certificate
Periodic Inspection Report for an Electrical Installation.
Schedule of inspections.
Schedule of Test Results.
Schedule of Circuits.
More Info
Water Heating Element:
Quickly find the size of Water heating elements needed for hot water tanks. Including: –
Temperatures
Times
KW rating.
More Info
Heating & Heat Loss Calculations:
Easily find the right amount of heating needed for all sizes of rooms/buildings etc in Just 3 Minutes...Guaranteed! Look Professional by printing out a Full Detailed Report and 3–D Bar chart. Calculates heat losses through walls, ceilings, floors, Air etc.
More Info
Air Conditioning:
Find the right size of Air Conditioning for any size rooms/buildings in Just 3 Minutes…Guaranteed! Look Professional by Printing out a Full Detailed Report and 3–D Bar chart! Calculates heat gains through walls, ceilings, floors Air, etc.
More Info
Power Factor Correction:
Save Money now with an Improved Power Factor, by improving Your Power Factor you will Instantly see a drop in your electricity Demand which means you will also see an immediate drop in your electricity bills and a Reduction in the Mains Cable sizes.
More Info
Installation Simulator:
Create Electrical designs in Just minutes – Print out Computer Generated “Single Line” drawings. Cable sizes, Voltage drops. Conduit sizes. Cable Schedules. Minimum Trip current needed to comply with Earth Loop Impedance test (amps). Actual let through current (amps). Maximum impedance values (Ze) and the actual impedance values (in ohms). Total impedance values (Zs) for the complete installation (in ohms). Touch Potentials. Save drawings in AutoCAD format NO expensive drawing programmes to master!
More Info
Transformer Regulation:
Know Your Secondary voltages for all Startup conditions and avoid “Brown Outs” or Contactor Chatter Calculates transformer secondary voltages for all Load conditions!
More Info
Short Circuit Calculations:
Easily Perform a Short Circuit Analysis of Your Installation in less than 1 minute, displays Fault Currents in MVA, kA, & pf. Print out all Your Results!
More Info
Circuit Designer:
Need to Find the Right size Cable for Lighting Circuits i.e. Street Lighting, High Bays, Fluorescents or any Series circuit in Just 10 seconds, create a Precision Design…Every Time!
More Info
Electrical Estimating Pro:
Quickly produce Electrical Estimates because all the Times to Install the Electrical Equipment have all been worked out for You. With over 9,000 items of electrical equipment (Expandable to 20,000 items), create Assemblies and Sub Assemblies to speed up the Estimating Process it’s so Easy producing Professional Looking Estimates and Quotes and takes just minutes!
More Info
Control Wiring Schematics:
Easily Complete all Your Control Wiring Schematics for Electrical, Electronic, Hydraulic, Pneumatic and Fire Alarm Controls Circuits. symbols to ANSI and IEC standards.
More Info
Installation Optimiser:
Amazing New Intelligent software analysis and selects Every Cable size in Your Installation for You Automatically including all Voltage drops creating a Precision Engineered Design with 100% accuracy. This means no more calculations, no more trying to work out voltage drops, No more Design work, No more Drawings to do, No more outsourcing, no more mistakes and Your job is completed 100 times Faster…Truly Remarkable! “Single line” and “As built” drawings including “Three phase schematic” diagrams are all computer generated in an Instant and fully marked-up with all Your Results, this means No more drawings and no expensive drawing packages to buy is needed…The Ultimate in Design Technology! The Short Circuit calculations, Earth Loop Impedance Compliance Testing, Touch Potentials are all completed Automatically and a Full Total Quantities Parts List produced in Just Seconds! For Existing Installations you can Input every cable size and Check for Compliance or Re-design it! - The Only Design Tool You’ll Ever Need!
More Info
Calculate Temperature Rise in Your Boards:
Now You can Easily Know the temperatures in your Boards, i.e. Distribution Boards, MCC’s, Main Boards etc. Now Finding the temperatures at the Mid-Point and Top of Your Boards is as simple as:- Input Your Board’s dimensions and select the equipment being fitted That’s it! Add Vent sizes and reduce internal temperatures, it’s so Easy-to-Use.
More Info
Co-ordination & Discrimination Study:
Now it’s Quick and Easy to Plot and display all Your Fuse/Circuit Breaker trip curves. Adjust pickup and instantaneous settings to achieve full coordination. Curves to ANSI and IEC Standard, printout tables and log/log displays.
More Info
Come on peeps......there must be other people who would benefit from this software out there......to go and buy it would cost around £880!!!
Grab yourself a bargain and for a good cause.:)
ends tomorrow (friday) 10pm please pop the time you bid on it tomorrow night as i am not around at 10 pm to watch it. thanks
well done to highest bidder, swear words could have been said here due to the fact that I'm away from home and been tryin to bid using my mobile but site kept refusin my password until too late( nothin ta do with any drink that I may have consumed tonight! :rolleyes: )
Seriously though, well done :)
Sold to trypod thank you. Sorry Mike71 you were a minute late.
trypod Re: **CHARITY AUCTION**... 2 Hours Ago, 09:59 PM
Mike71 Re: **CHARITY AUCTION**... 2 Hours Ago, 10:01 PM
Checked it out Mike71 was 1 minute late. Trypod is the highest bidder before 10.00pm.
Like BigBreakfast said, trying to log in on a mobile is difficult to say the least. Had to borrow someone elses phone to put the bid in!
It was before 10.00Pm when I sent the bid but not registered until 10.01.
Moderators decision is final I guess so well done to Trypod.
I hope you'll at least match my high bid, it is for charity after all!
Cheers, Mike
Cheers, Mike
Sorry about that Mike but on this one we had to stick to the rules.
Cheers, Mike
Mike I will pay £250 if you match that amount for the Clik software you won
It's for a good cause
Kev
Hi Kev, If you read my thread in the business section "self employed, who's busy, who's not" you'll see i'm currently unemployed and don't have the extra money for that.
I bid on the software, which I would have put to good use. My bid came in a minute late. I congratulated you and asked you to at least match my high bid.
If you choose not to, that's up to you. Either way well done on winning the software.
Cheers, Mike
**CHARITY AUCTION** industrial pro software
For Sale and Wanted Forum
Phil,
Phil,
