M
Martin G
Hi Guys,
I'm tweaking the layout to my garage and I'd like to put a cabinet against the wall right where my conservatory sockets are fed from. Due to this I need to recess a junction.
I had planned to mount an adaptable box in the wall and chase a channel out for some conduit, however I'm not sure the block work is up to it. The wall is made from 100mm blocks and my adaptable box is 2" deep, it feels like I'd need to remove far too much of the wall to make it work.
Rather than a box and choc connector in the wall, could I simply use a crimp connector to extend the cable, running it into some conduit. This way I could avoid taking 2" out of the wall. I understand this would make the joint inaccessible, is this ok?
Cheers,
Martin
Cheers,
Martin
