chasing in oval conduits and filling in chases advice please | on ElectriciansForums
Discuss chasing in oval conduits and filling in chases advice please in the Australia area at ElectriciansForums.net
G
Guest112
Hi guys, before starting this thread I have searched old threads on this site and had no luck finding a good one. I started a thread a few weeks a go my house rewire and now im after a bit of advice on filling chases.
I rarely do domestic electrical work so have barely touched on chasing, the jobs that i have done/been on in the past involving chases have been done by labourers.
im going to chase in oval conduits and would appreciate advice on how you guys fix the conduits in before filling, a colleague of mine says he pins in the conduits using nails to hold the conduit before filling with a sandy concrete mix leaving 3mm for skimming after. Does this sound good?
as far as chasing the drops im either going to borrow a wall chaser if i can or use a grinder with diamond disks and scutch out the center.
to cut out the boxes im going to use a grinder to cut the square and chisel out the centers by hand after fixing the metal backboxes and running in the conduits i plan to fill the chases and cuts with a concrete mix with 1 part sand to 3 parts concrete and leave the 3mm gap for skimming over.
a few things im wonderingn are first of all is there anything wrong with anything ive said and also what cables will fit down a flat 20mm conduit? im guessing i need 25mm drops for the 2 2.5mm twins for the rings
thanks in advance guys
Big headed galvanised clout nails fixed into the mortar joints in the brick or block work are suitable for holding the conduit in place.
I would use bonding instead of sand and cement to bulk fill the chases then multi finish or the like for the final finishing depending if your patching up the walls or skimming over a complete wall.
I also pva the chases before bonding 1st with a weak mix of pva & water then once dried go over again with a stronger pva & water mix (3 parts pva to 1 part water) let it go sticky or dry then bonding over the top
great advice so far guys really appreciate it after a bit of further researching im to understand that bonding can actually absorb moisture so in bathrooms so better to use a bit of cement instead but seeing as ill probably have to buy a bag of cement anyway i might aswell use that up ( I have other jobs i need it for also) ,
ill pvc the chases and the pipe? to help it stick and fill like i said leaving a gap of about 3mm and use finishing plaster? or multi finish? seems easy enough in theory
ive noticed that everyone seems to use their own method some using bonding, some sandy cement, some using onecoat plaster etc i was expecting there to beone strict method but it seems its an each to their own kind of thing,
again anymore advice would be greatly appreciated
hello one tip you might find usefull is score a few chases into the wall with your grinder where your boxes are going to make chasing that little bit eaiser i often find this helps, but be warned its very dusty using a grinder and ive never used one in a lived in house hope this helps and good luck
cheers mate, trying my best to borrow a chaser, grinders my last option but its my house so ill be the one putting up with the dust but id rather not lol yes my mate recommended cutting accros vetically and horizontally in each backbox and he reckons it helps a lot
Not to hi-jack the thread but, are you required to use conduit,seems like all the old cable I'v hauled out of walls is just plastered over and held in by metal wrap round clips and nailed in,
Pict
no isnt required i could use capping or just skim over the cables directly, but i dont particularly like using capping as it jams the cable to the wall and if i just skim over the cables if a fault develops ill have to smash the plaster off to replace the cable, not that i expect any faults but you never know,
im mainly using conduits because being a spark and seeing as its my house i thought id go the extra mile and seeing as the capping id need is as wide as the chase needed for the conduits just a bit deeper i might aswell,
im also not that experienced domestically and having used capping id like to use the egatube to compare methods for the future when i plan jobs etc,
AND... im not sure how long i will be living in the house so future proofing aswell mate
yes my plan is to record the rewire and take pictures step by step of the whole rewire explaining calculations and reasons for doing things etc im going to speak to one of the mods or admin to see if they can help me about it considering its my house and i have all the time in the world to do it it gives me a chance to take pics and whatnot ect
Reply to chasing in oval conduits and filling in chases advice please in the Australia area at ElectriciansForums.net
