Chasing out walls... | on ElectriciansForums
Discuss Chasing out walls... in the UK Electrical Forum area at ElectriciansForums.net
E
entech
Ok then lads, who uses what tools to carry out the wall chasing we all know and love....:63:
I've had the fortunate experience of having played with quite a few chasers. Had a metabo one ( basically a grinder with 2discs and a 50mm spacer between them). It wasn't great, far too much stoor. Had a few variations of them on different sites. The one I'm using the now is the bees knees. A hilti se20 with a hilti vcd50 vacuum are great. When chasing I don't even need to wear a dust mask. Bad point - Tends to trip the trany thermal cut out if using for more than like 20mins so we have to sometimes use 2 tranys. Very expensive to buy tho but you get what you pay for. And for channeling the brick out I've got a 110v Bosch multi drill or a 230v version with a50mm bit and a 70mm bit for back boxes
Reply to Chasing out walls... in the UK Electrical Forum area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
And if it's a garage then use metal clad accessories.
