chasing out | on ElectriciansForums
Discuss chasing out in the Australia area at ElectriciansForums.net
smithjim0001
hi all
i need to chase out for a new fused spur but my only and i mean only option is to chase up to a corner and then around onto the other wall.
not chased into a corner is it allowed? clearly its still horizontal cant find any where in the regs that say its not allowed.
Any advice
thanks
jim
chase up vertically above yor fcu, then horizontally within 150mm of ceiling.
Im extending the ring to accomadate a fused spur for some lighting and the socket is normal height so what your all saying is i cant chase around a corner unless its at high level can anyone give me the page number of OSG or regs on this.
Cheers
Reply to chasing out in the Australia area at ElectriciansForums.net
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
Luckily when I rejigged the socket to fit the fcu next to it, it meant the original ring wiring reached, i put the socket on the ring and took a...
