Chasing out | on ElectriciansForums
Discuss Chasing out in the Australia area at ElectriciansForums.net
P
Peter Woodford
This may a simple question sorry if you are installing sockets and the floors are concerte would u chase them out or drop down cables from above floor space in a old house or new build
Cheers
Why would you want to chase out concrete floors.Seems like hard work and time consuming.Me personally i would drop the cables from above and put them in trunking if surface mounted or chase the wall out and cap the cables:confused:As long as they're in the safe zone
If you are working on a new build and there are concrete floors in place, chances are they are bison slabs, it is a huge nono to interfere with a bison slab, and could lead to jail if you were to do something that resulted in a colapse.
Reply to Chasing out in the Australia area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
Thank you for the speedy response! Have seen them on top of plaster in steel conduit before but guess it's not a common desire to have wires...
