Hi
We haves moved and new place has a bedroom with double plug socket in internal stud wall. There is a spur off this to another double socket which is mounted on (not in) adjoining wall but around a corner and about 3 metres away. However cable is protruding outside of side of first socket and tacked along skirting and then round corner to other wall mounted socket sitting just above skirting but housing is loose.
I want to chase along walls and bury existing cable and put the other socket into wall with double patress and wire it up.
Basically hide cable which will run about 5 to 10 cm above skirting along first wall, round corner then along to second socket.
Floor is not an option as horrible tongue and groove type board.
Is this allowed full stop and can I do this as a DIYer. Technically just rewrite of existing cable into new socket in wall?
