Chasing | on ElectriciansForums
Discuss Chasing in the Australia area at ElectriciansForums.net
I
irishsailor
Chasing cambles in walls how deep do the chases need to be, cables are RCD protected
Chris
They don't have too be a certain depth if they are protected by an RCD. Anything that chased more than 50mm in needs too be protected by an RCD.
I'd go down about 30mm with the wall chaser, chisel it out and put the cable's in 25mm oval conduit too give it protection
As long as you can get a minimum of 4-5mm of spread over the conduit or capping it should be fine .
If the plaster is to thin it could cause cracking in the fininshed wall.
Reply to Chasing in the Australia area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
Yea I do It was more the spd at solar end I was more enquiring about than rcbo just wanted to confirm it for my own sake as I was questioning...
