I am working on a chiller system that runs a hydraulic pump as well as a cooling fan. I was sent out to replace the control board for the system as well as a contactor.
I have a transformer running 24VAC to A1 on both the pump contactor and fan contactor as well as a port on my control board. The A2s are tied to separate ports on the control board.
Long story short. One of the brand new contactors is clicking off and on. (Apparently had been before I got called). I have measured the coil voltage for both contacts. The one that is working correctly is a constant 24V. The other runs fine and when it clicks, the voltage jumps up to 28V. I am unsure of what to check to remedy this. For me, it seems that the voltages should be the exact same across the coils.
