I need to joint a 2.5/3 SWA to a 1.5mm HO7 then bury it. Don't need to worry about glanding the armour as it's good the other end (I suppose I could bond it to the cpc if we're being picky).
A 'proper' expensive IPX7+ box is a bit OTT for the job, and a SWA joint kit might not like the twiddly 1.5mm. Was thinking about just using some strip in a small adaptable box then filling it with resin?
