Cheap voltage tester | on ElectriciansForums
Discuss Cheap voltage tester in the Electrical Tools and Products area at ElectriciansForums.net
L
LloydusT
Hi,
Looking at ordering a cheapo voltage for odd jobs around the house, what are single pole voltage indication and phase rotation test used for?:D
Don't buy cheap, if your going to insist on going near electrical then spend the money and buy quality. Why would you put your life in the hands of a cheap tester??
Fluke T5-600 will cost about a ton and last you a life time and will not let you down
ARGH ARGH.......I have lost 2, YES 2 fluke voltage/continuity indicators in 2 weeks!!!!!!!!!!!!!!!!
.Going to buy neon screwdrivers from now on!
by cheap I meant a fluke T100 or T120 but do like the look of the new megger voltage tester.
When I say not needed I refering to Measuring single pole voltage and for measuring phase rotation.
T120 is a good bit of kit!! You do need to follow a procedure when testing L-cpc or it will take out rcd's but I would pay the extra for the 120
Phase rotation you don't need
We've just added the Megger TPT210 and Megger TPT220 to the site. Megger have also released a new proving unit: MPU690 to complement the new voltage & continuity testers. If you require any information or would like to place and order please call 0113 248 9966 and quote "ELECFORUM" for a further 5% discount!
What are you guys charging for fluke T-5's these days
Our Current prices are:
Fluke T5-600 is ÂŁ79.95
Fluke T5-1000 is ÂŁ89.95
T5 Holster is ÂŁ19.00
All units are in stock and can be shipped 1 - 2 Business days. Please call 0113 248 9966 to order
One of mine has come home!
Nearly bought a T5 today, good prices above!
Did by some new grips and mine were then found in the scrap (Beer fund)cable!
Reply to Cheap voltage tester in the Electrical Tools and Products area at ElectriciansForums.net
Thanks again, I’m sure I’ll be back with many more questions
Hi all, The electrical network in my house (Antwerp, BE) is quite old and consists of two phases of about 140 volts. This gives me approximately...
