Checkbox CB 300 - Help needed!! | on ElectriciansForums
Discuss Checkbox CB 300 - Help needed!! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
chrisgc
I have just purchased a second hand Socket and See Checkbox CB 300 but it does not have any instructions with it or the card (presuming it should have one) which is stuck to the inside of the lid?
Does anyone own one of these calibration units and have instruction manual I could maybe downlaod?
And also is the card what I believe should be stuck to the lid inside required ie. does it have any recorded results on for the calibration unit itself.
Any info or help would be gratefully appreciated.
Chris
Reply to Checkbox CB 300 - Help needed!! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
The power company only brings in 3 wires which is 2 live and 1 neutral wire. It’s our responsibility to add the ground rod to bond the neutral...
Okay, thank you. The language just threw me because it was, you MUST remove power, then it says to test, as in the middle pic, with power...
