Checking for breaks On A Long Cable | on ElectriciansForums
Discuss Checking for breaks On A Long Cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
lknights1987
Adaleighhh
Hi all,
I know how to check for breaks on short cables from end to end but how would i check for breaks on a long cable ( over 20 metres) using a multimeter?
If it's a single cable.....a test lead.
DIY.….beginning to worry me.
I'm not worried....not until i find out if it's connected to anything or not...:)
Once you test and determine there is a break,the fun can then start, using your meter to measure resistances calculate exactly where along its length that break has occurred
Simply check continuity,on each conductor,until you find O/C....then,pull the copper inner conductor,out of the insulation.
Then,measure the length of that copper,and note it down.
Measure the total length of the cable,deduct the length of the copper,and then measure that distance,from the other end.
....This,is where your break is. ;)
then when he's cut the cable at the break, re-insert the copper conductor he's pulled out, and repair. :D:D:D.
Reply to Checking for breaks On A Long Cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If you look up the Anstoss ZIG2 igniters there are different versions, but either mains voltage, or 300V dc which produce 20kHz output, so I don't...
I use this one, copy this into a search engine: 200EP Tone Generator Kit High Accuracy Cable Toner Detector Finder Tester with Inductive...
