checking rcd tester | on ElectriciansForums
Discuss checking rcd tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
zone77
Barrow
i ve got my NICEIC inspection at the end of the month and just wondered if using a cheap plug-in RCD unit is ok for testing if my instrument is accurate.:cool:
Anytime i have had the NIC out i have had to use a check box to prove accuracy of test instruments.
Surely to prove that your test instrument is accurate you should have been checking it since your last assessment...................................:confused:
In that case, you should label the plug-in rcd unit for the pupose for which you intend to use it - remember that you
[ElectriciansForums.net] checking rcd tester
ust use the same unit each time. The important thing is CONSISTANCY in the
ethod that you use.
Reply to checking rcd tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
