Chemical fixing or Resin fixings to secure trunking | on ElectriciansForums
Discuss Chemical fixing or Resin fixings to secure trunking in the UK Electrical Forum area at ElectriciansForums.net
Hi
Have a job on a very old historic building and the architect is asking for the trunking ( white plastic 25x 40) which is horizontal for about 12m to be secured by chemical / resin fixings
This is not something I have come across before,have used resin fixings before for a rawlbolt type of fixing but that's not gonna work for pvc trunking let alone the fire rated clips
Ideas ?
Or any pointers for fixing in general to really old to crumbling walls
Any Help as always much appreciated
The architect spent years at Uni and at great expense studying for his degree and then worked in a menial capacity at a "firm" to gain knowledge and experience to become a jumped up know it all with unattainable ambitions,
To be honest just look him straight in the eye and say the following "you're the genius so tell me what I need to use"
A Resin will do the trick, even holding the fire clips but more likely to cause extensive damage to the building if and when the trunking/resin needs to be removed!
Yes the resin is likely to hold a filing cabinet to the wall! But will it sustain its adhesion with the effects of a fire??
I doubt he or she is 'jumped up know it all' or sees themselves as a genius. Just somebody doing a job to the best of their ability.
Yep,this is true,but to have the confidence in specifying a particular product,he or she,must be able to have knowledge of the type,supplier and method.
Any architect or similar,who comes back with the often trotted "Well you are the installer...what do you normally do..." may often,not know,themselves.
Not knowing the state of what is being drilled,and,not withstanding the ugly choice of containment,it may require an initial base or track to be fixed,on which to fix the trunking.
I can think of several better methods,and of several ways of doing what has been asked,all of which rely on further discussion,and elongating someones budget :)
Reply to Chemical fixing or Resin fixings to secure trunking in the UK Electrical Forum area at ElectriciansForums.net
