chip board floors !!! | on ElectriciansForums
Discuss chip board floors !!! in the Australia area at ElectriciansForums.net
Circuler saw between the sheets works fine,but a word of caution check the saw depth does not quite clear the board depth those water and gas pipes are waitng for you to cut just that little bit to deep ;)
Sharp broad blade bolster can also get the job done, not so quick and clean though.
I bought a Bosch 180 multi tool, cheap version of a Fien at ÂŁ60. How did I work without this before? Superb, plunge cut through floor boards in difficult to access areas & to cut out skirting board sections. Have a look at Fien's site which has videos of use. Cordless versions of both now available.
I've used the Trend Routabout tool to cut holes in chipboard floors. The off cut fit's into a plastic ring accessory to make good the hole... very neat. Word of warning though... the cutter bit costs about ÂŁ30 and usually only lasts 3 holes before burning out the bearing, so you need to budget properly for the holes in your estimate for the job.
Reply to chip board floors !!! in the Australia area at ElectriciansForums.net
Fix-a-floor. For fixing tiles with voids. Got to use this fix-a-floor stuff today. What a load of... rubbish, and that's being kind. One loose...
smokie899
Floor tiling 600x600 48m2 Hello, this is my first post here, but I have been doing some reading. I am going to be tiling the whole ground floor...
Spacebug
