Choc Block in a plastic enclosure on a lighting circuit... Is it compliant? | on ElectriciansForums
Discuss Choc Block in a plastic enclosure on a lighting circuit... Is it compliant? in the Talk Electrician area at ElectriciansForums.net
DNS1
Fitting new downlighters (2 independent lamps) and was planning on adding them to the end of the lighting circuit in my loft using a suitably rated terminal strip, inside a surface mounted plastic enclosure.
Read somewhere that this wasn't compliant, can someone enlighten me? Have I got the wrong end of the stick somewhere?
Only just learning the building regs and 7671, so I'm pretty new to this. Been doing dodgy DIY myself for years, but trying to do everything properly from now on...
as long as it's accessible, no problem. i would prefer to use wagos though.
Reply to Choc Block in a plastic enclosure on a lighting circuit... Is it compliant? in the Talk Electrician area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
