Choosing a power supply, switch fuse size | on ElectriciansForums
Discuss Choosing a power supply, switch fuse size in the UK Electrical Forum area at ElectriciansForums.net
Yanu
Ireland
Hi all, I'm new here.
I have qualified back in 1990 and worked only a few years in the trade. Now I'm back and I find myself a bit "rusty" and in need of a bit of help...
I have to wire a complex of coldstores and I have to make a fuse boards for a part of them. I have 6no 10 amp MCBs, 2no 20 amp MCBs and 8no 20 amp RCBOs in it. Just a few lights and sockets circuits. I have no idea what's going to be plugged in and for how long, the client can supply single or three phase.
What size switch fuse do you think I should use?
Thanks in advance
If you don’t know what’s being connected or for how long the loads are on the circuits you won’t be able to apply any diversity to the load. You need to speak to the client as others have said.
Who decided on the protective devices and their ratings, how was this decided on? Surely you must have had some design spec.
Thanks in advance
Are you registered with RECI?
Thanks for your comments guys, I have more information this morning.
I'm not registered with RECI, I'm employed by a company that builds coldstores and they only require my qualification to sign them off.
There are a total of 25 lights, 5 foot LEDs, they are only 63 w each. I'd like a separate MCB for every room. 6 rooms, 6no 6amp MCBs?
My employer says that the sockets are for general use and to go with the maximum rating to cover ourselves. There are from 4 to 8 in each room. 6 circuits, 6no 20 amp RCBOs? I might wire the ones with 8 sockets as a ring.
There are 2 spurs for hand driers, 2no 20 amp MCBs?
2no panasonic air conditioners, 2no 20 amp RCBOs or MCBs, not sure
Back in the days I use to wire the mains to a switchfuse in the consumer units, is that not the case anymore?
You really shouldn't be undertaking the work if you're not confident in your own knowledge and competence because if something goes wrong you're responsible and you will have to justify everything and every decision you've made from the design, installation and testing. Asking here gives you no cover should YOU cock something up.
I'm sure there are times when you are not sure about things right?
Usually these coldstores are straight forward to wire and I have no problem with them. Sometimes we get the odd job and I can't say to my boss that I'm not doing it...
Do you think my guess on the breakers is not right?
If I'm unsure of anything I refer back to the relevant legislation I don't go on forums with a vague outline of proposed works to seek confirmation. You should have all the correct design and cable calcs for the installation and that should provide you with all the info you need. If you don't.....Well what are you playing at
I have no choice and I have to do the job.
Unfortunately I don't know as much as you about the trade but it is what it is... I can't change that.
I don't think my choice of breakers is far from what it should be, you still haven't express an opinion about that.
If you have no intention of helping, you don't have to keep replying otherwise we will be both wasting our time to get anywhere.
Thanks for your comments so far
So are you going with the 'maximum rating' or 20A??
Either a Ring Main (it's Friday and that's going to annoy quite a few people) or a Radial.
Reply to Choosing a power supply, switch fuse size in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
  • Solved
Please use the like button to thank, like or whatever. As the forum treats that as a positive message then and uses it to score members.
    • Optimistic
