Choosing replacement ballast | on ElectriciansForums
Discuss Choosing replacement ballast in the UK Electrical Forum area at ElectriciansForums.net
Volt66
Birmingham
Hi all. I have two bathroom cabinets which each use two T2 15W fluorescent tubes. Each tube has its own ballast which are pretty expensive to replace and go about every 12 months.
Just wondering what ballast would be able to replace both of these, or if anyone can give me some ballast calcs to work from. I used to be a sparky but never came across this.
I'd make the switch to LED but haven't found a strip that gives out anywhere near as much light as these do, but I'm open to suggestions.
Thanks in advance!
Reply to Choosing replacement ballast in the UK Electrical Forum area at ElectriciansForums.net
https://www.nationallighting.co.uk/amalfi-gu10-6-light-spotlight-bar-dimmable-adjustable-matt-black?vat=1&gad_source=1&gclid=CjwKCAjwhIS0BhBqEiwADA...
You really need an inductance or LCR meter or a ring tester which are expensive to buy but you can make your own ring tester if you want a project...
