Just did a small church what i nightmare and have a few questions on coding
The heating is by rusty tube heater groped in to 5 per radial circuit and their are 4 circuits and each circuit is feed buy its own 15amp cartridge fuse in the main CU
Now the good bit
To switch the heaters on and off they have mounted a second hand 4 way plastic enclosure below the CU and fitted 2x32amp mcbs and 2x20amp mcbs to act as switches
I am at a bit of a loss on how to code this as technically what's wrong?
Each heater has no separate means of isolation but the flex just goes into a imperial conduit box and connects using old ceramic blocks
are the ceramic blocks still ok?
Now the good bit
