Cig Lighter fuses keep blowing | on ElectriciansForums
Discuss Cig Lighter fuses keep blowing in the Auto Electrician Forum area at ElectriciansForums.net
Jordan
Canada
1991 GMC Sonoma compact pickup
So i am guessing the previous owner installed an after market lighter socket as it has an inline fuse behind it. The lighter is also connected to a blade fuse in the fuse box. I checked continuity on the lighter and I have a closed circuit. When I got it the online fuse was five amps. I tried a few AGC fuses until they stopped blowing. The blade fuse is supposed to be 20A so I settled with a 20A AGC behind the lighter. But now when I install the glass fuse, the blade fuse in the fuse box blows! What is happening here? I thought this would be simple....
what rating is the blade fuse ? 10A is normal for a cig. lighter . also, see if it blows with the lighter part out of socket.
The blade fuse is 20 and that’s also what the manual says to use. The socket is clear of debris and has no lighter to put in it. (I just want to use it to power devices)
Taking your multimeter, remove the in line fuse and insert one of the probes. Place the other probe in contact with a known ground/earth and check for continuity.
If there is continuity, there is a short circuit.
No continuity, there should be no problem.
I take it that the 20A blade fuse does not blow until the in line glass fuse is inserted?
if you check for continuity from the lighter side of the in line fuse holder and the body of the lighter you should get open circuit.if it's a low ohms reading, then the lighter socket is buggered.
Reply to Cig Lighter fuses keep blowing in the Auto Electrician Forum area at ElectriciansForums.net
