Circuit breaker has tripped | on ElectriciansForums
Discuss Circuit breaker has tripped in the DIY Electrical Advice area at ElectriciansForums.net
Deckkie
UK
I found that the circuit breaker had tripped on the downstairs lighting circuit after a light didn’t turn on. I don’t know what caused it but I found the the water heater breaker had also tripped (I assume is the water tank heater in the airing cupboard). I could reset the water heater but the lighting won’t reset. There is no evidence of any leakage from the water tank that might have caused the problem, all the downstairs lights are turned off but the circuit breaker still won’t reset. All other circuit breakers are ok.
Any ideas or advise please?
Can you show a picture of your consumer unit so we can establish what type of device has tripped.
It’s a Wylex unit, here’s a photo (looks like the water heater has tripped again though we never turn it on).
  • [ElectriciansForums.net] Circuit breaker has tripped
Does the lighting one actually go on or not.
The lighting one doesn’t reset, if you try to it just crackles and goes off again.
When you say crackle is it more extreme than that.
It’s just a crackle as I don’t try to force it on all the way, just enough to tell that it’s not going to stay turned on. I don’t want to risk burning out any wiring.
You can't hold it on against a fault - the lever will disconnect from the internal mechanism, but the sound you describe does sound like the noise a MCB makes just before it trips on overload.
Yes so if it’s tripping with all the lights turned off at the switches it points to something on the internal wiring (rather than something like a blown bulb that’s still shorting out). I can’t imagine what fault on the internal wiring could come on with it just sitting there undisturbed. Maybe something to do with the water heater but I can’t imagine what, there don’t appear to be any leaks. The water heater breaker still resets ok.
You need an electrician to do some proper testing. Don't keep closing the MCB when there is a fault present.
Strange that both MCBs have started tripping.
One possible fault I can think of,
Looks like a car charger has been fitted more recently than the rest of the installation. (Right next to breaker that is now causing problems)
Could be a cable is loose and arcing if cables have been moved but not checked for tightness.
I think you need to get an electrician to have a look.
Ok thanks all very much for your replies, I thought perhaps it might be something simple I hadn’t thought of. I’ll get someone in but wifey wants to wait until after the lockdown as most of the lighting is from plug-in lamps which obviously still work ok.
Reply to Circuit breaker has tripped in the DIY Electrical Advice area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
