Circuit Breakers Not Breaking! | on ElectriciansForums
Discuss Circuit Breakers Not Breaking! in the UK Electrical Forum area at ElectriciansForums.net
DomW
help!
I've just tried doing what I thought was a simple replacement of a plug fascia as the old one got covered in paint during some decorating. Turned off the power at the breaker, ensured the circuits were dead, removed the old plug front, wired in the new plug and replaced the fascia back on. I've then turned the breaker back on, plugged in a lamp to check the plug works and fine.
I've then gone to turn the breaker back off (to do the next plug in the room) and none of the appliances turn off when I flip the breaker.
When I throw the RCD in addition to the breaker they do go off.
Any ideas what I've done? I can't see how in the process of changing one plug frontage to another I've created a short.
No, I think they're all on one circuit. The troublesome breaker is marked up for the living room complete and the first time I flipped the breaker the entire room went out.
Totally confused now. Ran through each breaker individually to confirm exactly what turned off when tripped. Flicked the living room and everything went off. Back to how it should be. Thanks for your help!
I'm sure you know that you have failed to follow safe isolation and also the requisite dead and live testing procedures in accordance with performing minor works?
This is frowned upon. Many on here, including myself can show you personal photographic evidence of this type of work gone wrong.
Please be careful.
Reply to Circuit Breakers Not Breaking! in the UK Electrical Forum area at ElectriciansForums.net
Given the apparent lack of earth, combined with no short circuit or over current protection, I'd contend that luck has been the sole factor...
nicebutdim
N
