C
Chris Ward
Can anyone shed any light on this for me.
Im putting in a supply to an outbuilding to supply a 13a water heater & 3a light, but picking a socket up on the way. Im wiring it in 4.0mm pvc twin cable from the DB, then 4.0mm 3core armoured outside. There is a DP switch incorporated near the DB in order to isolate the outhouse power from inside. The route the circuit will take is this:
(-> = Cable between)
(main building)DB1 -> 32a RCBO -> 32a DP Switch -> (goes outside) Outdoor twin socket -> (into outhouse) Un Switched FCU to supply water heater (13a fuse) -> Switched FCU for lighting (3a Fuse)
Im pretty sure this meets requirements for 433.1 Radial final circuit. Anyone got any input?
