M
markjenks
Hi, after abit of advice.
Wanting to install a new aditional circuit for a lathe. Technical info on label says this lathe runs at 3 phase, 2500 rpm 54A. There are already Lathes installed with same spec but circuits installed to run these are currently BSEN 60898 type b breakers, using 4mm single core PVC, with cable run length approx 10-15M. Rather than just installing what's already in, I wanted to check all sizes, breakers, cable etc. My calculations come back much higher than what's already installed although everything is working and tested out/certified ok?
Any ideas what I could be missing when following cable calc procedure through BS7671?
Cheers. Mark
Cheers. Mark
