Circuit in garage | on ElectriciansForums
Discuss Circuit in garage in the Australia area at ElectriciansForums.net
F
flukeyspark
Hi all,
Im gonna install a new circuit in my own garage & use it to show as one of my jobs for the NICEIC, so it needs to be spot on.
I have a spare way on the cb on the RCD side so ill use this.
Now is it best to install a radial or ring final? All im putting in there is about 4 2 gang socket outlets. Also is it best to run the cable in conduit or is acceptable to clip to the wall exposed?.....................:confused:
Any ideas most welcome.............. cheers........
If you want it to be spot on run a 2.5mm radial around the garage in 25mm black plastic conduit, you can spur off this for the lighting. As you have stated that you can rcd protect this circuit that is great, but don't forget to make sure that you have 10mm bonding cables to gas and water as this is the first thing he will check.
Rules of assesment,
1 : Make him cup of tea
2 : Do not answer questions he hasn't asked
3 : If he offers advice look grateful
4 : Make sure you have all the documents, test records etc ready for him.
Good luck with it all.:D
Hi
Ring or radial does not matter, it might be better if its a radial though because on your inspection the inspector might ask you to test the circuit, easier to test a radial than a ring main when under pressure. You will need to install the sockets out of hitting distance of the car, so at height or above a work bench. A domestic garage you can install clipped or trunking or conduit it depends how exposed the cables are. If you wanted to you could clip at high level then drop with trunking/conduit. With the NICEIC as long as you can explain what you have done and why you should be OK.
Regards
Or if your really nervous a capachino with some exlax and say when he arrives you have a stomach bug after 10mins he wont hang arround long enough for a 100% inspection and if you come across really compitant in first 10mins you should pass no worries.:D
hi kung
think it means feeding the garage from your house ;)
best check with nic flukeyspark.
think you have to do a job that would be notifiable under their scheme as thats what you are trying to enroll onto.
you are quite right about testing but that goes with anything you do as a spark.
think they are only interested in anything covered under the scope of part p.
dont forget if its not covered under part p then you dont have to notify labc either and nic normally like to see completion paperwork including labc sign off.
The main db is in the garage with a spare way.............would it be over excessive to have another at the side of it....................? Thanks for the help.... glad this is making people scratch there heads as well, it seems to be another "grey area". Im pulling my hair out here...............
Hi all,
Just for the record, Ive been on to the NICEIC helpline & they have said that as the garage is attached to the house & the cu is in there, a new circuit is notifiable, & is therefore acceptable to show in a periodic assessment............. None the wiser to be honest...........
therein lies the answer.:)
i thought you had a detached garage, not sure why :confused:.
that is why there is a comment about running a feed across the garden to it is notifiable.
glad you got it sorted.
all the best with the assessment.
let us know how it goes.
Reply to Circuit in garage in the Australia area at ElectriciansForums.net
This potential client seems to be making progress in terms of being interested in proper chargers and answering my query questions. I have also...
Thanks for the input guys. Lighting track is out of the question. The routing (h section guirders and angle iron) means that swa cable clipped...
