Circuits for Motors- how to in the UK? | Page 2 | on ElectriciansForums
Discuss Circuits for Motors- how to in the UK? in the UK Electrical Forum area at ElectriciansForums.net
Cookie
Earth
How do you size the MCB, wire and protection for a motor in the UK/Europe? How is it typically done?
If anyone is curious here how its done in the US:
You size the conductor based on 125% of tables 430.247-430.250 determined by the type of motor and duty cycle of course. (When Table 430.249 says 2 phase they don't mean 180* out of phase like in 120/240 but 90* out of phase- this was common 100 years ago during the electrification of the United States but obsolete today)
This will then take you to table 310.15 B 16:
60*C or 75*C based on your wire and termination. Typically you use 75*C, and de-rate (more than 3 conductors in a conduit) off the 90*C column as THHN/THWN is rated 90*C. Once the conductor size is known you size the fuse/breaker based on Table 430.52.
For a breaker you can size at 250% of the conductor's ampacity (current carrying capacity), for a none time delay fuse 300% and for a time delay fuse 175%.
Remember there is no loop impedance requirement- meaning you can place #14 (2.08mm2) on a 40 amp breaker and run it as long as you like, ie 500 feet or more.
Next, you size the motor's overload protection based off 115% to 125% of the motor's actual nameplate rating.
If any of you have 3 hours time to burn, here is a crash course on the subject;
Over all idea under the NEC:
View: https://www.youtube.com/watch?v=_7FmwY442dQ
Sizing the breaker/fuse (Short circuit and ground fault protection of the wires):
View: https://www.youtube.com/watch?v=nvJaaWGJMo0
Sizing the conductors:
View: https://www.youtube.com/watch?v=Sic1uoua3og
Sizing of the overload protection for the motor and wires:
View: https://www.youtube.com/watch?v=2cprO8ZdT1U
  • [ElectriciansForums.net] Circuits for Motors- how to in the UK?
90 degree 2 phase is not something we've ever had here and it is always nice to learn something.
I think we have used it here historically in a couple of supply systems, I would have to look it up. IIRC there were two implementations, one used equal sized supplies and symmetrical motors, the other used a lower-rated 'teaser' phase with 1-ph load always on the main phase.
I always cringe when people call a circuit using two line conductors from a 3-phase supply '2-phase' as it's often more trouble than it's worth to explain why it isn't!
I find it quite odd that you would look up a current rating in the book based on HP rather than using the FLC of a motor.
I believe the logic, and perhaps Cookie can comment, is that the circuit (which is not adjustable after installation) should be sized to allow sufficient ampacity for any standards-compliant motor of that power that might be fitted now or in the future, that might have a marginally different FLC compared to the one specced at installation time. But the overloads are set according to the particular motor in use, based on nameplate FLC.
You got! :)
The code mandates larger wire in the event the new motor coming in has a higher FLC. Also, HVAC techs, electricians and maintenance guys are always told to re-adjust the motor overloads when replacing an old motor with a new one. Its common to forget.
If you look at old power lines that are still in service in US cities you can even see the remnants of 2 phase power. Often the cable riser pot will have 4 bushings and a 4th insulator (without a conductor in it) on the cross arm or the cross arm with have insulator pins in multiples of 4 instead of 3. The 2 phase was abandoned and changed to 3 phase decades ago but the old stuff remains.
[automerge]1575483695[/automerge]
Here is a pic I took of one of those poles 10 years ago:
[automerge]1575483750[/automerge]
Only the pic to the right is mine, the one on the left is AR's from Ipernity.
2 Phase power was mentioned in this thread. Here is post where a US electrician is replacing it in a US installation.
2 phase power does still exist in select locations throughout the US.
A similar-but-different situation that we sometimes find in the UK is the presence of two lines and a neutral in the service cable to an older building. Because we've never used split phase 120-0-120V in the UK it is not common and usually indicates a legacy configuration, found in one of two kinds of locations.
One is where it was intentional; high load installations (e.g. farms) in rural areas where the only HV nearby was single-phase. For these, we supplied split phase 240-0-240 and ran large motors etc between the outers at 480V. It's the same deal as US 120-0-120 but twice the voltage, however we never added a high-leg to make it into a 3-phase service, i.e. it never formed part of an edge-grounded delta. Some of these installations still exist.
The other reason for two lines, found in towns, was a consequence of the switchover from DC to AC. Where the original distribution and service cables were laid for 3-wire DC, there were two outers and a neutral. Alternate houses would be supplied from the +ve outer and -ve outer, with larger installations receiving both outers to run motors, heating etc at 480V. When these areas were changed over to AC, a new 4-wire distribution cable was needed, but the existing service cables were often retained. 3-wire service cables were connected to two phases and neutral, resulting in 400V between the lines, not 480V. This is never supplied to a customer as a single supply, only as two separate single-phase supplies. I have this in my house, which has its original 1920s 3-wire DC service cable. As they are on different phases both lines can be fully loaded without overloading the neutral, so I can have 2 x 100A 230V supplies for a total of 46kW.
Your service reminds me of what they do in very densely populated areas. They will hang a 3 phase transformer and run 120/208Y 4 wires down the street. Business get 4 wires, while homes only 3 (two hots and a neutral).
Meet Mr. Big and Tall :oops:o_O
Reply to Circuits for Motors- how to in the UK? in the UK Electrical Forum area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
