Citroen C4 faulty DRL repair | on ElectriciansForums
Discuss Citroen C4 faulty DRL repair in the Auto Electrician Forum area at ElectriciansForums.net
KaneHa
Livingston, Scotland
Hi everyone, I have a 2015 Citroen C4 with a faulty DRL / position lamp that I’m trying to repair instead of having to replace the full headlight unit. When the Headlights are off the DLR flickers and when switching the headlights on the same bulb (which acts as the position lamp) fails to light.
Power has been checked using a feed off the opposite headlight which confirmed the LED unit has failed. I’ve since split the headlight and removed the offending item but am struggling to source a replacement part. I wondered if anyone here has suggestions of suppliers of these chips?
Reply to Citroen C4 faulty DRL repair in the Auto Electrician Forum area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
Ah OK, that makes sense. Thank you Avo.
