Citroen Relay Window Weirdness | on ElectriciansForums
Discuss Citroen Relay Window Weirdness in the Auto Electrician Forum area at ElectriciansForums.net
PD2323
Gloucester
Hi there.. I have a 2013 Relay. The electric window switches in the drivers door started playing up, only working intermittently. I took off the door panel and looked at all the wiring.. all looking intact as far as I can see. The passenger window works from the passenger door switch perfectly. I replaced the switch panel 3 times (2 different parts suppliers - both non-genuine but claiming to match the part number).. With the replacement switches the windows didn't work AT ALL, but the central locking (on the same panel) has kept working with all of them. The original (to me) switch panel does still work intermittently.. sometimes only a clicking noise from inside the door panel.. windows not moving. All I can think is to try a genuine Citroen switch panel... unless anyone has any other ideas? Thanks!
Reply to Citroen Relay Window Weirdness in the Auto Electrician Forum area at ElectriciansForums.net
Thank you for the suggestion!
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
