H
hillbillie
How do you do an earth bond test for these? I have re read the IEE code of practice on this but I can't find an answer apart form: "...can give misleading results"
For example a class 1, totally plastic vacuum cleaner, at least on the outside (it has tiny metal screws not screwed into earthed metal). If there is nowhere to stick your lead can it be tested? Should I just do a visual and the insulation resistance test?
