Class 2 floodlight preferably with PIR but doesn't matter?? | on ElectriciansForums
Discuss Class 2 floodlight preferably with PIR but doesn't matter?? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Dare I ask why Class 2 Steve?
Oh Mike!! I knew the question would be asked :smile5: but tried to avoid as I'm sure they'll be something wrong!!
The customer has a class 1 metal halogen floodlight attached at present, it is broken. I thought this will be an easy one!! I turn up and there is no earth to the light (its not just snipped off and hidden). The customer does not want another cable run to it.
The data sheet states it has to be earthed Mike. I have looked at a number of plastic/polycarbonate ones thinking they may be double insulated but haven't found one that states it.
The one's I've linked are very definitely double insulated, that's why I linked them.
Then you don't replace the light! Simple really.
Reply to Class 2 floodlight preferably with PIR but doesn't matter?? in the UK Electrical Forum area at ElectriciansForums.net
That will work fine as long as the Pirs use relay switching, some don't.
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
